how to change z-value in a specific region in intensity graph
Hi all!
I have an intensity graph and I want to mark a specific region which is dark and then change the z-value(autoscale) so I can see what's in  this region, of course the rest of the intensity graph will be very bright but it's not a problem.  How do I do that?
Thanks in advance
Giang
(2,834 Views)
Easiest method is to change the z scale, unselect autocscale z and rescale the max and min z to the max and minimum region of interest.  This can be easily automated, by using the roi as a subset of the input array and then get max min of the subset and feed it to the z-scale property max min.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,826 Views)
Hi Paul!
Thank you for your answer, I will try to do what you have told me.
Best Regards,
Giang
(2,814 Views)
