how to chart maximum and average for signals in a dataset run?
i would like to chart the maximum value and the average value for the signals in each dataset run (while the numbers of runs could reach 10000 or more). is there a way to get statistics of each run by channel of data in the run?? i will be stripcharting 64 cutting tool load profiles for each cnc station(10 total) on a transfer machine. i would like to see long term trends as tooling gets dull.
(3,186 Views)
The Citadel ODBC interface offers some features through SQL that are not implemented in the DSC functions. You may want to get the SQL toolbox. There are SQL query types to extract averages, min/max, number of points, etc.
(3,186 Views)
