01-17-2017 02:10 PM
hello I am using NI USRP 2932 device and software for this is labview 2013 version.I have to ask two questions.first does NI USRP 2932 is compatible with labVIEW 2013?since It is a development system.
second question is that how can I check that labview has been connected to the USRP device?my device has been detected by the host computer successfully as shown in the configuration utility
01-18-2017 09:21 AM
The readme for the NI-USRP 16.0 driver states that it is compatible with LabVIEW 2013.
If your host computer has detected the USRP, then you should be able to call the device by IP Address in LabVIEW. The answer to your second question is located in the NI-USRP 2932 Getting Started Guide. Please give this document a look if you have any more questions!
Stephen
