how to choose some points of graph and make them highlight
hi,
   i am a learner. i am sorry to disturb you but i really need your help. there, i  build a graph and i want to choose some points of it and make them more obviously just like the picture as follow.
   thanks and best wishes for u
(3,313 Views)
Hi xyl,
how many of this points do you need? You can use cursors. The attached picture shows, how it can look like.
Hope it helps.
Mike
(3,306 Views)
Two easy possibilities:
(1) Use the plot images property:
Open the example finder and look for the following example: Graph Plot Area Images.vi
(2) Use annotations:
look for example: Programmatically Annotate a Graph.vi
(3,295 Views)
hi, Mike
   thanks for your answer. First of all, the points will not be the max nor min number and the quantity of the points is variable. it will be 2 or 5, it also will be more than 100, just according to the need of you .And of course , the quantity of the points will be less than the total points of the graph.  so, i think using cursors is not a best choise. Is there another method? thanks
   xyl
(3,229 Views)
hi, altenbach
   thanks. it seems the example of  "programmatically annotate a graph.vi" has the same results as i want. but the points i choose are more than 2 and they are random. i am trying to learn how to slove the problem. thanks
  xyl
(3,226 Views)
Well, just make a subset of the datapoints that you want to annotate and then annotate them in a loop.
Seems easy enough. Are you having difficulties with this?
(3,208 Views)
