how to clean ex xy graph
Hi All..
I have an xy graph which is plotting coordinates of x and y values. I keep the data as using shift register and feedin arraz of values with that shift register. My problem is that i want to clean old graph displayed when i start new run.. There is no any history option in the property noke. as an example i attach a vi imitating what i want to do.
what is the most secure, easy way to do so_
thanks
Message 1 of 8
(3,864 Views)
Use the Initialize array function to initialize the shift registers to 0.
Andrew Alford
Production Test Engineering Technologist
Sustainable Energy Technologies
www.sustainableenergy.com
Message 2 of 8
(3,855 Views)
You can do several things.
1 - create a xy graph variable and before entering the while you connect an empty value;
2 -  create a xy graph reference and select value property. The connect an empty value;
Basically it's the same.
i've changed your vi.
Software developer
www.mcm-electronics.com
PORTUGAL
Message 3 of 8
(3,851 Views)
Thanks Jorge..
Could you please convert it to LV 7.0 Smiley Happy
Message 4 of 8
(3,832 Views)
IOOIOI
It's not possible. I only can convert to 8.0.
Sorry
Software developer
PORTUGAL
Message 5 of 8
(3,826 Views)
snapshot would be ok too!
Message 6 of 8
(3,823 Views)
IOIOI
It's in the attached.
Software developer
PORTUGAL
Message 7 of 8
(3,820 Views)
thanx...
Message 8 of 8
(3,811 Views)
