how to close a vi automatically?
for example, after a vi(frontpanel included) has been executed, could
it be closed automatically? (not only stop the vi,but also close the
frontpanel)
I accomplish it through the vi property node and invoke node, it seems
that this method isn't so weell.
(2,946 Views)
You are right. This is to be done on property node->frontpannel->open and set it to false, as far as I remember.
Pawel
(2,946 Views)
Hi Plainman,
Take a look at the example I posted here
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=137&HOID=5065000000050000001457010...
I believe it demonstrates one method that you may find helpful,
Ben
Ben Rayner
Certified LabVIEW Developer
www.DSAutomation.com
(2,946 Views)
thank you,Ben!
It is a good example indeed!
thanks a lot!
(2,946 Views)
