how to combine multiple signals to one waveform plot in labview
hi everyone, im using labview 2011 and i need to take four different signals and plot them individual in one waveform chart and THEN i need to combine all four signals and plot the resultant in the SAME waveform chart as the four original ones. i have the four signals plotted but can not for the life of me figure out the resultant one. any ideas? thanks!
Message 1 of 11
(10,906 Views)
The word "combine" can have many meanings. Do you want to sum them, average them, concatenate them, or something else...
Message 2 of 11
(10,905 Views)
Also, please show us your code. What is the data type (arrays, waveforms, dynamic, etc.)
Message 3 of 11
(10,902 Views)
our instructions say "combine the signals and plot the resultant" so im not exactly sure. I would imagine he wants the average
Message 4 of 11
(10,900 Views)
they are dynamic. ive attached a screenshot of what i have.
Message 5 of 11
(10,894 Views)
bump
Message 6 of 11
(10,849 Views)
Sounds like homework.
If you're not sure what combine means, I don't see how anyone here can know. You should realize that you can wire the signals to the basic arithmetic functions to do the add and then divide if it truly is the simple average you need.
Message 7 of 11
(10,847 Views)
im pretty sure i just need to average 4 waveform signals and plot them. if i just try to use the addition function it gives me an error saying the waveforms have different values (duh).
Message 8 of 11
(10,837 Views)
I think you mean different start times. I don't touch dynamic data with a ten foot pole but you can align the timestamps or convert the dynamic data to 1D dbl arrays.
Message 9 of 11
(10,823 Views)
that didnt help. ive figured out how to average the signals pretty easily, but i dont think either of the ways ive figured is what i need. im not even sure if what i need to do is possible. when i plot the 4 signals in the chart, everything is fine. when i plot "combined" signal alone in a chart its fine. but when i try to do all of it the chart gets all messed up. i know im asking a pretty general question with a difficult answer, so i understand if nobody can help. and i do appreciate your efforts, by the way. i just cant get this stuff to work correctly
Message 10 of 11
(10,817 Views)
