how to combine this two program as i am using two ni my daq to connect
may i ask know do i put my program into this program as i making reading different measurements using two ni my daq
(2,947 Views)
Hi HanKiat,
I sugest you to avoid using express VI. Here is a link that will help you to improve your code using DAQmx API.
https://www.ni.com/en/support/documentation/supplemental/06/getting-started-with-ni-daqmx--main-page...
Good luck.
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
(2,914 Views)
