11-19-2007 08:57 AM
11-19-2007 09:19 AM
If you don't want to program in LabVIEW, why did you post to the LabVIEW board?![]()
You really need to provide some more details on what type of hardware you are using - digital I/O, analog out, analog in, number of channels, acquisition rate, etc. From that, some appropriate substitutions might be found. Posting to the Multifunction DAQ board is probably the best place.
In any case, you are going to have to do substantial rewriting of the old code to use new hardware.
11-19-2007 10:02 AM
Hi:
As I said, I'm new to this envoriment and I didn't where to place my question. Anyway, the proces is a heat exchanger and the objective is to control the outlet temperature by changing flowrates. We use a multivariable control system to maniputale the valve positions based on the temperature measurements. As for the hardware, the actual daq is an OPTO-22 B1 with 4 T/C and 2 4-20mA that measure temperature and flow respectivelly, all the inputs are analog. I have 2 4-20mA analog outputs that send the signal to the valve actuator. The software we use was writen in quick-basic(back in the late 80's), this software runs on the DOS-plattform. The computer we use to run this proces is a 386GHz.
Based on the above, is it possible to perform any modifications that would help to use the dos-based programs? or what do you suggest me to do?
tahnks for your comments...
luisky
11-19-2007 10:17 AM
11-19-2007 10:24 AM
You need to communicate between a dos PC with QuickBasic and another (modern) PC with NI hw.
Try serial communication, or file communication if connected to a network...
Both ways you have to change the QuickBasic program minimally.
11-19-2007 11:07 AM
