how to communicate with Micrex-F Fuji PLC
hello to all
i want to read/write address of Micrex-F fuji PLC but this model is not available in OPC server. what is other way to communicate with PLC and how?
asif
(4,201 Views)
Hi Asif,
I am assuming that when you say you want to read/write from the fuji PLC you mean to read and write form LabVIEW. Based on this, there are multiple ways to communicate a PLC with LabVIEW. I would recommend you to check this document and define which is the interface that is more convenient for your project.
Hope you can find this information useful!
Sil.VI
(4,171 Views)
Thanks for your replay
i tried by  modbus but failed, as there is no Micrex-F fuji PLC in opc server so is it possible to that PLC in opc either by updating opc server of installing new opc server?
i have made project with siemens PLC as it is in OPC server.
any suggestion ?
(4,150 Views)
Check your PLC series with as follows link, whether NI OPC server supporting your selected PLC or not.
https://www.ni.com/en/support/documentation/supplemental/07/supported-device---driver-plug-in-list-f...
(4,147 Views)
my PLC model is not listed here. how can i communicate now. my PLC is Micrex-F Fuji PLC
asif iqbal
(4,130 Views)
If your selected PLC not listed in NI supported device list you can't communicate with NI OPC server. Meanwhile try out that in Modbus communication from follows attached files;
(4,118 Views)
cant do that....
Smiley Sad
(4,110 Views)
