how to communicate with a instrument which has its dll in C language
hi all
we had recently brought an instrument which has its dll wriiten in c language.i want to use it in labview.we are not able to connect to the instrument also.it has only lan .& i suppose its not taking the ip address & the port no.
to which format should i give them as they are structures which are passing to a function & i am calling that dll in the labview.
regards
dhiraj
(3,471 Views)
(3,468 Views)
ya i have been using this but its giving unable to connect to the instrument.
i have got a dll file & header file & a c file to connect to the instrument.so how can i use them to connect to the instrument
(3,436 Views)
Hi dhiraj034...,
you can use the import function of LabView to create the vi´s you need to communicate with your device, or you write them by yourself. Smiley Happy
Mike
(3,434 Views)
What is the instrument?
Who is the manufacturer, and the model designation?
If you provide these, I can check to see if some drivers already exist for it.
RayR
(3,423 Views)
@dhiraj03416 wrote:
...we are not able to connect to the instrument also.it has only lan .& i suppose its not taking the ip address & the port no.
Hi!
   I would focus on this problem, which is the first to be solved.  How can you say that's not taking ip address? do you have a DHCP server enabled? Also I'd check firewall settings...
graziano
PS.: of course, these are "blind" suggestions, I'd like to have your instrument on my desk to try....Smiley Happy
(3,420 Views)
