05-08-2008 03:08 AM
05-08-2008 03:20 AM
05-09-2008 03:05 AM
05-09-2008 03:07 AM
Hi dhiraj034...,
you can use the import function of LabView to create the vi´s you need to communicate with your device, or you write them by yourself. ![]()
Mike
05-09-2008 07:44 AM
What is the instrument?
Who is the manufacturer, and the model designation?
If you provide these, I can check to see if some drivers already exist for it.
RayR
05-09-2008 07:54 AM
Hi!
@dhiraj03416 wrote:
...we are not able to connect to the instrument also.it has only lan .& i suppose its not taking the ip address & the port no.
