how to compare lots of values
hello master , can you give me advice , im confuse how to create program comparison , below is little piece from the formula that im trying to fix
=IF(x>=3;10;IF(x>=2;20;IF(x>=1;30;IF(x<1;40))))
x = input number ,
any advice or code will help me thanks
(2,635 Views)
Hi kucink,
use a case structure with 4 cases…
(When x is a float datatype you should round to integer first.)
(2,617 Views)
Hi kucink,
As GerdW explained, one option is the Case Structure and wiring x to your selector.
Another option that might map more closely to your input statement is the Select node, which you could create a series of.
A discussion of "if" in LabVIEW can be found here: The LabVIEW Equivalent of an If Statement
GCentral
(2,599 Views)
Hi kucink,
no case structure/select node needed:
(2,582 Views)
finaly i can solve it , thanks for help guys Smiley Happy
(2,532 Views)
Glad you solved it, but that file doesn't look like it has anything to do with the solution 🙂
GCentral
(2,517 Views)
