how to compare signals from two different .tdms files?
i'm developing a lie detection system in labview.so inorder for that i need to compare the threshold physiological signals from the .tdms file with the signals i acquire continuelsy from the subject for each question asked.i use respiration monitor and heart beat monitor together with the sensorDAQ to acuire the physiological signals.so which are the function i should make use of?i have the following toolkits
1. advanced signal processing toolkit
2. adaptive filter toolkit
3. digital filter design toolkit
4. biomedical toolkit
please give me advise on this.
thank you.
(3,077 Views)
Accepted by topic author Irshu
Lie detector systems (polygraphs) generally work by looking at the physiological responses to the own subjects baseline, and do this in real-time.  You could use a file that represents the stored "baseline" for the subject, but the overall environment, circumstances, general state of the subject, etc. may not be similar enough to easily see subtle changes.
From the stored file, you might determine a set of parameters or thresholds that indicate "normal, relaxed" for each signal.  You could read the file into your LabVIEW program, process each channel, and save these parameters.  Then when you have the new data, you can read the new data file in and process it in a similar way and then determine whether the parameters are outside the limits that you established for a "lie".
You may get more responses to this question if posted in the Biomedical User Group
(3,071 Views)
