how to comply the program to save as the document by labview
Users randomly selected a file.The file maybe word or database. Then save as to the folder that uses optionally specify.How to achieve this function.
(3,276 Views)
Can you rewrite this question in clearer English?
"comply the program"  doesn't make sense
"to the folder that uses optionally specify" ????  Could you mean users?
Achieve what function?
(3,273 Views)
the functions:
     for example: when I run the program of labview
    1、 I randomly selected a file,the file can be word or database
    2、save as the file to another file that i can randomly select
how to comply the function.thanks
(3,268 Views)
the functions:
    1、 I randomly selected a file from a folder,the file can be word or database
    2、save as the file to another folder that i can randomly select
(3,265 Views)
"Comply the function" ???
Just use the Copy function in the Advanced File Functions palette of the File palette.  You give it the source path and the destination path.
(3,257 Views)
thank you very much .  I got it
(3,249 Views)
