how to compute the equation-group?
I want to comupte one equation-group using labview.what can I do this?Provided that here are one
eqution-group,one equation is 6x-9y=29,the other is
-9x+14y=-43;how to solve this !thanks a lot!
(2,532 Views)
I assume that you want to find an x and a y that solves the two equations.
You can solve one equation for y and then substitute what y equals into the second evuation to get a value for x. Then take the x value and sub into an original equation to find the y value.
If you are familiar with linear algebra, you can build an array of the coeficients then use Solve Linear Equations.vi . It is found in LabVIEW Full and Pro.
(2,532 Views)
