how to concatenate spreadsheet string to normal srting
        i try to  concatenate spreadsheet string to normal sring but it can't concatenate...here i attached my program for ur .the closed bracket  can't be concatenate.
(3,225 Views)
Accepted by topic author GokulGKM
Hi
Your string is getting concatenated but it is getting added in the new line. If you exapnd your string indicator you can see ")" in the new line.
Eliminate the \n character and you will get the required output.
(3,200 Views)
 Hi madhanskm
I hope attached VI will work as per your requirement.
pankaj
(3,185 Views)
