how to configure a shell and tube heat exchanger with Lab VIew to get data
There's no manual but this is the link with all the technical details:
http://www.adafruit.com/products/828#Technical%20Details
I think it sends out 450 pulses per liter of flow
Message 11 of 23
(1,530 Views)
What makes you think that the sensor "has positive, negative and a ground wire"? The description of the sensor says "The sensor comes with three wires: red (5-24VDC power), black (ground) and yellow (Hall effect pulse output)." In order to get it hooked up properly, you'll need to pay attention to these details. What DAQ device are you using? Does it have a counter input, which will make it much easier to measure pulses?
Message 12 of 23
(1,526 Views)
I'm using the NI USB-6008
Message 13 of 23
(1,520 Views)
it has analog input
Message 14 of 23
(1,518 Views)
The USB-6008 has a single counter input. I recommend that you connect the pulse from the sensor to that input (assuming the voltage levels are compatible - I didn't check). This makes it easy to count pulses in a given period of time, and since each pulse corresponds to a unit of flow, you can easily calculate flow rate. If you use an analog input, you'll need to acquire a fixed number of points and then analyze the data to determine the number of pulses in it. While there are functions to do a lot of that work for you, it still won't be as simple as counting pulses using the counter.
Message 15 of 23
(1,513 Views)
Thanks 🙂
When you say put the sensor into the single counter input should it go into analog side or the digital side?
Message 16 of 23
(1,489 Views)
I meant you should read the manual to see which pin is the counter input - looks like it's PFI0.
I haven't used a USB-6008 and am not completely certain of its capabilites. You may want to look at whether it's capable of doing a frequency measurement. If it can only do a single software-timed read of the counter, then your reading could be inaccurate because you'll need take two readings and subtract and you won't be able to precisely measure the time between those two readings. If the DAQ device can do continuous analog input measurements with hardware timing, then you may get a more accurate reading using the analog input but you'll need to do more processing, because you'll know the exact period of time over which the measurement was made.
Message 17 of 23
(1,478 Views)
hi I hope you are well 🙂  (I figured out how to get the pulse counter to work) I am now trying to configure the pressure transducer for labview it got to the pressure bridge set-up page after I told LabVIEW i was using a daq to read pressures from a pressure transducer
do you know how to input this infromation where it says configure scale:
Output: 0.5V – 4.5V linear voltage output. 0 psi outputs 0.5V, 7.5 psi outputs 2.5V, 15 psi outputs 4.5V
Message 18 of 23
(1,451 Views)
I'm not sure what you mean by "configure scale." Are you using Measurement and Automation Explorer to set up a task, or are you using the DAQ Assistant, or something else? A screenshot would help. You can easily convert that scaling information into a slope and an intercept, if that's what's required.
Message 19 of 23
(1,442 Views)
I attached the screenshots
Message 20 of 23
(1,434 Views)
