how to configure "call library function"?
I just installed a DAQ board in my compter and want to use it to control my multiplexer (ER 16). For communicating with the multiplexer, I downloaded some software for NI-DAQ 6.9-2 and support for labVIEW 6.0, which is the version of the labVIEW I am using. But all of the .vis don't work. The error infomation shows that there's something wrong with "call library function". I found then although i can find that function from the panel, i can't configure it by clicking the right key of the mouse. There's no such a item for me to choose. I wonder if this means this function isn't supported by the labVIEW I am using. Is there anybody who met such problems before? Any help from you is highly appreciated.
(2,674 Views)
Hello;
What exactly was the Software you downloaded for NI-DAQ 6.9.2? If it was an example code, maybe there is a DLL call to an external DLL that wasn't downloaded.
Please be more specific about what you downloaded, and also make sure the DAQ device you have is properly installed on Measurement and Automation Explorer.
Regards
Filipe A.
Applications Engineer
(2,674 Views)
