how to connect boolean function out to event in event structure?
how to connect boolean function out (any) ore nameric to event in event structure?
(3,405 Views)
Dear Motiteti,
What exactly do you want? To control an event based on "low-to-high" or "high-to-low" transition of a boolean function?
Perhaps you can provide more details and code to help us help you.  Meanwhile you can refer to this link if it helps.
(3,393 Views)
like this
(3,372 Views)
You are a beginner in LV. You should not start with an Event structure the learning curve. Start with the basics first. At the top right of the website (main forum page) you can find links for learning resources.
(3,351 Views)
thanks
(3,342 Views)
If you really want to trigger an event from the output of a function, do as shown in the attached example.
(3,295 Views)
thanks)
(3,241 Views)
