how to connect my multiplexer (CIO-EXP 32) into my data acquisition card (PCI DAS-1602)
I have a PCI-DAS1602/16 and I need a C100FF-2 cable. I also use CIO-EXP32 multiplexer which I need to connect it to my data acquisition card (DAS1602). I am wondering how to connect CIO-EXP 32 into PCI-DAS1602/16. Based on the catalogue, I need to get two CIO-Mini50 (50 pin terminal board) boards. I will be so thankful to inform me if I can use any other cables instead of buying two CIO-MINI50 boards in order to connect my multiplexer (CIO-EXP 32) into my data acquisition board (PCI-DAS1602). Giving me some information ASAP is greatly appreciated.
Yours sincerely,
Mehdi
(2,382 Views)
I would suggest you ask Measurement Computing.
(2,377 Views)
