how to connect "IMAQ Get Buffer.vi" output terminal of "Image Out" to the input terminal of "Image" of "IMAQ ColorImageToArray.vi"
Thanks a lot for helping me till this stage.I am again stuck up with some problem.Please help me this time also.
Actually i am making changes in already existingblock diagram and also i am new to this labview programming.And also time is very crucial.
So i want to know if there is any way to connect the output of Image out terminal of IMAQ Get Buffer.vi to the input terminal of Image of IMAQ ColorImageToArray.vi.
In the actual block diagram the output of Image out terminal of IMAQ GetBuffer.vi is connected to the input terminal of Image of IMAQ ImageToArray.vi.
I want to change this becos i want to take RGB image as input and seperate R, G, B components.
Please explain in terms of bloack diagram.
(2,661 Views)
Hi Subhash,
In order to help others who may run into the same problems in the future, I will be answering this post in your original thread.  I ask that you keep all questions pertaining to this issue there, so that if someone else encounters the same problem, they can follow it through from original question to completed answer.
Brandon M.
(2,640 Views)
