how to connect the output of my VI to a midi port?
I want my VI to send a midi signal to a Midi port to later play it using Kontakt (or any other VST or midi player). I do not want to play the midi in Labview. How can I connect the midi port to Labview?
I really need anyone's help, and thanks 😄
Message 1 of 12
(4,652 Views)
Did you try a search? http://forums.ni.com/t5/forums/searchpage/tab/message?filter=location&location=forum-board%3A170&q=m...
Look through the previous posts to determine which one matches your situation. You haven't indicated what you actually have in terms of hardware, so I have no idea which solution or suggestion best fits your needs.
Message 2 of 12
(4,641 Views)
Hey, tnx a lot for ur post, well I already checked those forums but I didn't find what I need. My request sounds simple: I have a couple of IR sensors that I connected through a NI USB-6009 DAQ and everytime a sensor is activated I want Labview to send the relevant MIDI signal to a VST so that I play the relevant music from the VST  (or if there is a sub VI that does the work of the VST, I wouldnt mind using it instead) .
PS: I have tried using an internal midi port like LoopBe1 but I am not able to access it from Labview.
Thanks again 😄
Message 3 of 12
(4,628 Views)
Hey, I just want to reformulate my question to be clearer: I want my VI to talk to Kontakt. Now Kontakt would expect an input from a virtual midi port (I am using be1 as a virtual midi port). What I basically need now is to write from my VI to the virtual midi port. PS: I am using Labview 2010 Tnx again 😄
Message 4 of 12
(4,618 Views)
What is a "VST"? What is "LoopBe1"? What is "Kontakt"? You said you wanted your VI to talk to Kontact. What does that mean? Is Kontakt a piece of hardware? Is it a software application? What API do you have available?
Also, please use full words instead of text-speak (ur -> your). This isn't Twitter. Thank you.
Message 5 of 12
(4,615 Views)
Could you please clarify your setup. What kind of software and hardware is involved and how is it connected together.
Sev K.
Senior Systems R&D Engineer | Wireless | CLA
Message 6 of 12
(4,602 Views)
" Virtual Studio Technology (VST) is an interface for integrating software audio synthesizer and effect plugins with audio editors and hard-disk recording systems. VST and similar technologies use digital signal processing to simulate traditional recording studio hardware with software"
This VST takes as input a midi signal from a midi port. I want to send that signal from labview through a vitual midi port (Loop be1 is an example of a virtual midi port). How can my VI communicate with a midi port instead of the " Microsoft GS wavetable synth" ? (In other words it would be the same as switching a music keyboard with my VI) .
Thank you,
Nadi
Message 7 of 12
(4,587 Views)
Hi Nadi,
Have a look at the this tutorial. You can use the VI's from midi-example.llb  to output a signal to the virtual midi port, provided that this port is recognized by Windows and has a valid Device ID.
Sev K.
Message 8 of 12
(4,576 Views)
I have a large MIDI rig (including Kontact 5 Player in my DAW).  The posts that you saw are probably all the help you're going to get on this subject.  You are not going to find a MIDI palette in LabVIEW any time soon.  Smiley Sad
You're best bet is to learn some C++ and the MS dll that handles multimedia and wrap the MIDI parts in a new dll that you can call with LabVIEW CLFN.
EDIT: BTW, DEFINITELY start with the library linked above by Sev.  It will provide a good example of using the CLFN. Smiley Happy
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 9 of 12
(4,567 Views)
This response has a very low Signal to Nastiness ratio. IMHO
Message 10 of 12
(3,985 Views)
