how to connect to an OPC Server
Hi all,
I am trying to connect to an OPC Server from within LabView (6.1).
I have used the example vis, but I can only get a variable once when the vi is started. The value is not updating if it is changed on the OPC Server. With an other OPC testclient it is working fine. I put a OPC Logger inside the connection and found the following difference: Labview sent the command READ(), while my testclient sent the command ONDATACHANGE(). Can anyone tell me how to get labView to also send ONDATACHANGE() ?
Thx in advance
(3,253 Views)
Hello Viper,
"I have used the example vis, but I can only get a variable once when the vi is started."
Which example VI(s) are you using? What's your OPC server?
It's been awhile for me to do it this way, but I just used the LV6.1 'Datasocket OPC' example "Multiple OPC Items Monitor" to connect to a couple of OPC servers I've got running and had cts updates. Or are you using the LabVIEW DSC module?
Fading out. " ... J. Arthur Rank on gong."
(3,235 Views)
Yes I am using this example. I get cts updates, if I connect to the NationalInstruments.OPCDemo server, but I do not get cts updates if I connect to the OPC Server I need. I found out that I get cts updates from there as well if I connect to this server with LabView and also with a second OPC Client(Factorysoft client), at the same time. It seems to me that the Factory soft client is doing something what tells the server to send the variable on datachange.
(3,216 Views)
“... I do not get cts updates if I connect to the OPC Server I need. I found out that I get cts updates from there as well if I connect to this server with LabView and also with a second OPC Client(Factorysoft client), at the same time.”
Weird.
I regret that I can’t offer any useful suggestions other than perhaps taking a look at or playing with the configuration of your OPC server. I’ve only connected to OPC servers with Datasocket a few times when debugging/testing LV DSC apps and haven’t had the problem you’re encountering.
Hopefully someone else will pop in with better answers than me.
(3,177 Views)
