how to control picture animation
hi every one
i want to control picture animation, i mean i have picture of rotating motor so  i wanna when i press button it rotate and if i press again it stop rotating
can anyone help ?
(3,030 Views)
The simplest most efficient approach would start by import the frames of the animation into a PIcture Ring and the sequencing can be done by writing new values to the Picture Ring to select the various frames.
If the sequence of frames is undefined at development time, then use a Picture Control to display a series of image read from file, or generate the images progaramatically.
I hope that gets you started,
Ben
(3,009 Views)
There was a fairly long and detailed thread on this subject awhile back.  You can find it here.  That said, I agree with Ben.  That is how I usually do it.
(2,999 Views)
(2,985 Views)
