how to control the 3ds max 8 using activeX through labview?
Im working for a project that requires me to control the 3ds max 8 through activeX by using the Labview. Does anybody have reference or example on how to control the 3ds Max 8 using activeX through labview 8.2?? Many Thanks.
(2,447 Views)
Hi Thang,
What aspect of 3ds MAX are you trying to automate?  Do you know what ActiveX calls to make?  If so, please refer to the following articles that explain how to use ActiveX within LabVIEW:
Using ActiveX with LabVIEW
ActiveX and LabVIEW
Also, LabVIEW 8.2 contains ActiveX examples in Help » Find Examples » Communicating with External Applications » ActiveX.
(2,423 Views)
