how to control the plot range
Dear,
I would like to turn off the autorange option in a waveform.
The data have changed so that could be seen oscillating.
To overcome this problem, I want to set the maximum and minimum of the waveform.
I can't find some options of the waveform function.
Please let me know if there is a solution for this.
Thanks in advance.
(2,849 Views)
You have got to use the property node. On the diagram panel, right click on the control, Create->property node, Click on the node, select Y Scale->range, rest work would be straight forward to wire the range cluster or picking up Minimum or Maximum seperately.
(2,849 Views)
