how to convert 2D arrays to 1D array
Hi
its a example for split a 2D array to two seprate 1D array
Message 11 of 16
(4,842 Views)
This is overly compicated pure Rube Goldberg code.
See also my reply to your other post.
Message 12 of 16
(4,829 Views)
Hi, Altenbach
Can you help me? Sorry for post in here, but I'am a new user and I couldn't find the right place to post.
I have a 2d array that I convert to a 2d Matrix, but I need to convert this matrix (in fact, this matrix is a image, where each pixel is one element of the matrix) to a 1d array (or 1d matrix, I don't if this is possible). But I need that every single element being present in this new 1d array, I can't lost none of this elements.
In essence, I need an algorithm that put "each column below the other".
This is how my code is until now.
Message 13 of 16
(4,776 Views)
Why do you need a matrix?  Just work with arrays.
You can use reshape array.  You justy need to transpose the array first.
This is Altenbach's message 9.  Just with the transpose array added.
Message 14 of 16
(4,766 Views)
Hi jvc,
you can create new threads by posting a question. Did you notice the "How to…" links in the upper right of the main forum page?
On your question: one TransposeArray does the trick:
Edit: RavensFan was faster - with the very same solution… 😄
Message 15 of 16
(4,764 Views)
Thank you so much for your help and the next I will post in the right place! Smiley Very Happy
Message 16 of 16
(4,751 Views)
