how to convert a number array to a string array quickly and easily?
(3,835 Views)
you can use the 'array to spreadsheet string' vi.
hope this helps
(3,831 Views)
this vi just output a string not a string array .
(3,827 Views)
Wire the output to the 'spreadsheet string to array' and wire a string array constant to 'array type'.
(3,823 Views)
quickly and easily?
The Number to String functions are polymorphic. Simply wire your array directly into the Number input and you will get an array of strings.
___________________
Try to take over the world!
(3,820 Views)
