how to convert a number into an ascii code
Hi,:
I just start to use Labview. i plan to use the labview to talk to Rs232. here is my question:
i have unsigned 8 bits number, i plan to convert the number into a letter so that i can send it to RS232. for example, i have unsinged number 85, i want to convert it into "U" since "U" is the corresponding letter of ascii code 85,
can you please tell me how i should do it,
thank you,
Message 1 of 9
(3,724 Views)
Make sure the unsigned number is 8 bit (U8), then use typecast.
Message 2 of 9
(3,722 Views)
Hi, Christian:
Thank you for your message!
i used the type cast, but it seems VISA write can not recognize it, what is the problem?
Message 3 of 9
(3,686 Views)
Sorry, see the image
Message 4 of 9
(3,683 Views)
I don't see any visa write in your image.
Message 5 of 9
(3,678 Views)
Message 6 of 9
(3,664 Views)
sorry, it seems i can get the correct character of the corresponding ascii code. however, it seems input is wrong. see the attached error message
Message 7 of 9
(3,656 Views)
The error is in "cofigure serial port", way before the string operation. Make sure all inputs there are valid. How do you define the visa resource?
Message 8 of 9
(3,635 Views)
Thank you for your message.
it seems i did not define the  com port correctly
Message 9 of 9
(3,623 Views)
