how to convert binary string to hex
How would one convert
0001101001001111 in string format to 1A4Fh
thats for any help in the right direction
(3,968 Views)
Use the function Scan Value (found in Functions - String - String/Number Conversions). Wire the binary string into the string input. Wire "%b" into the format string input. Wire the output to the Number To Hexidecimal String function found in the same palette. The output of that can be wired to a string indicator. Or the numerical output of the first function can be wired to a numeric indicator with the Format & Precision set to hexidecimal.
- tbob
Inventor of the WORM Global
(3,966 Views)
Thank you this answered my question completely
(3,955 Views)
