how to convert data from serial port to an integer????
I am sending the adc reading on serial port and i want to convert the data acquired from serial port to an integer and plot it on the graph.so, how can i get the continuous data from serial port?
also help me to convert serial data to an integer.
(5,323 Views)
Reading from a serial port - use the serial VIs located in palette under Instrument IO:Serial.  There you will find various VI's such as configure port, read, etc.
To convert your data, I would suspect the string conversion VIs in the palette under Programming:String:Number/String Conversion would do the trick.  There you will find various VI's that will convert almost any format string into a numeric such as a decimal string "123" into a decimal 123 or a double 123.0, etc.  The one you want is most likely Decimal String to Number, but that depends on the particular format of your string.
(5,314 Views)
Don't use the Serial functions.  Use VISA.  Trust me on this, it is a much better interface.
Look in the LabVIEW Example Finder (Help->Find Examples) and looks for a Simple Serial Write & Read (or something like that).  It is a decent start for learning to use the API.
Now for converting the string data, well that totally depends on the format the instrument is putting out.
(5,307 Views)
The "serial" palette VIs are actually VISA (at least in my palette).
(5,293 Views)
You need to change only string to interger
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(5,285 Views)
I guess in strict technical terms, that is correct.  If you want to turn them into meaningful integers, you have to know the format, as @crossrulz pointed out.  (Which, of course, could bring us full circle and your solution is the correct one, after all.)
Bill
CLD
(Mid-Level minion.)
(5,263 Views)
