how to convert digital pins to pwm pins in myrio labview?
how to convert digital pin to pwm pin in myrio labview for 10 servos
Message 1 of 8
(1,109 Views)
NI myRIO: "PWM" Express VI
Controlling the speed of DC Motor with NI myRIO PWM and H-Bridge
https://tmesystems.net/
Message 2 of 8
(1,092 Views)
sorry that solution didn't help, I'm lacking pwm pins on myrio
Message 3 of 8
(1,027 Views)
So what is your definition of PWM pins ?
Is there a reason that you can't use the PWM outputs that already is there ?
Message 5 of 8
(1,010 Views)
I am lacking for the pwm pin, the pwm pin there is already used by another servo.
Message 6 of 8
(1,005 Views)
Hi abimkeren,
You can implement any behaviour you need using the FPGA of the myRIO.
DIO pins can be used to output PWM signals or to measure PWMs/frequencies/duty cycles…
Message 7 of 8
(1,000 Views)
An your are using all 6 PWM pins ?
Then the only option is to make your own PWM signal in the FPGA.
Or in the Real Time part if it is a slow PWM frequency.
Message 8 of 8
(990 Views)
