how to convert excel file to txt ?
i want to convert file excel to txt
Message 1 of 14
(7,113 Views)
you go into excel and save as csv (comma separated value)... this is a txt file, you just have to ignore the extension
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 2 of 14
(7,109 Views)
thanks for your help, but I need of a VI in Labview
Message 3 of 14
(7,075 Views)
This is the kind of descriptive information you should include in an original post. Remember you are asking other people to solve your problem for you. This works because you leave behind breadcrumbs for other people to search/read/use in the future.
For example, a well stated and answered post has Previously answered this. Because they were detailed in what they wrote back then, it is easy to search for their solution today.
________/~~~~~~~~*********~~~~~~~~\________
Certified delinquent LabVIEW developer. Recertifying at next NI Days
Message 4 of 14
(7,071 Views)
I need of a Vi for convert excel file to txt
Message 5 of 14
(7,079 Views)
Please post what you have tried so far. What version of LabVIEW are you using? I think after 2012 or so the report generation toolkit was included with LabVIEW, which makes it relatively easy to work with Excel files. It does require that you have Excel installed on your computer to work with Excel files.
You would use report generation toolkit (search for it in the functions pallet) to create a new Excel report, with the Excel file you want to convert as the "template" input. (It's a little counter intuitive). Then you can use a read data or get data function to read the text from it, and use your choice of however you want to write it to a text file.
Message 6 of 14
(7,070 Views)
I'm using labview 2015
Message 7 of 14
(7,063 Views)
Great! Give it a go and report back with any troubles.
Message 8 of 14
(7,055 Views)
Message 9 of 14
(7,050 Views)
I did not realize I was posting on a duplicate post before, so here is a copy of my response:
Message 10 of 14
(7,049 Views)
