how to convert image to base64
Hey Guys ,
I am trying to convert image to base64  . I am using vi attached . But My result is not correct .since I am not able to converted base64 data into image using online converter.  Please suggest what is wrong in this vi or if there other way to convert image into base64 in LabVIEW
Thanks : Soumya
(3,253 Views)
Accepted by topic author soumyas
(3,212 Views)
Hello brother, I have the same problem as you.
I want to Base64 encode an image.
But my Base64 encoded data is wrong! It has many "A", I don't know why!
It is completely different from the correct Base64 I got on the web page. I am very worried.
I put my pictures and programs below. Thank you for your answer
thank you
(2,702 Views)
