how to convert numeric value to string value means if i enter the value 10 its shows ten in indicator
please help any one
(3,748 Views)
Hi rocker,
you need to write some conversion routines based on the language you want to use.
Or you need to search for routines already made for that purpose. I remember OpenG (or similar) already had such VIs…
(3,746 Views)
hai,
you have any attachments for that
(3,743 Views)
Hi party,
start VIPM and look for yourself for the OpenG add-on…
(3,741 Views)
yes open g has ,
Good Luck
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
(3,730 Views)
hai,
without openG how i build that one.?
(3,703 Views)
Hi party,
you need to analyze your number value.
Then you split the number in its decimals and use case structures to concatenate a string from corresponding words…
 In general: you need to do some programming! 😄
(3,699 Views)
