how to creat a BPF
I have a program of analog output (sine wave at 20 kHz freq) and an analog input which samples the analog output.
I need to create a BPF after I create the sine wave.
any help and thoughts?
thanks in advanced
(4,060 Views)
Hi Naama,
- what is a BPF? (Are you talking about Bandpass filters?)
- why do you convert your data to DDT wires? The DAQmx functions work better with "plain" wires like "array of DBL!"
- Why do you need a bandpass just behind the signal generation function?
- What's the point in using DAQmx IsTaskDone when you don't read its output?
- What's the problem at all? Apparently you already solved your problem!?
(4,028 Views)
Hi, and thank you for your response.
What I need to do is a sine wave that need to go through Bandpass Filter- this will be my analog output and then I need to acquire this signal in my analog input channel.
the problem is when I added the filter the program doesn't work well there is an error (200284)
I have added the program.
(3,993 Views)
You are loosing the timing information of your sine wave by using the Dynamic Data Type. Stick to the waveform, and you shouldn't get an error:grafik.png
Regards, Jens
Kudos are welcome...
(3,986 Views)
Jens, thank you very very very much!! you helped me a lot.
Happy new year!
Naama
(3,954 Views)
Hi Jens,
Just one more question because I am new in Labview.
I have add the new program with your comment and I look at the filtered signal graph and it doesn't look different though the inquire data look different.
I work with the X-series USB-6341 so the sampling info is now 500kHz.
thanks in advanced,
Naama
(3,946 Views)
