how to create 2 plots xy graph in excel
I need help!
I am trying to create a XY graph in excel which has 2 Plots with a bit different X and Y scales and i am not able to understand how to do it, It should be easy
basicly i have a table already imported into labview but i cant understand how to create a graph similar to the graph in the attached xls.
Please see attached xls file with an example for the graph i need which is created from the table inside the xls.
Thanks!
(3,311 Views)
Create clusters of the different sets of x and y data and then build them into an array and feed into the graph. For example....
(3,299 Views)
Thanks, you helped me!
(3,287 Views)
