how to create a NULL/Void waveform
so that the waveform graph will not display anything,
when there is no waveform for it
(4,002 Views)
An empty constant could not be created but you can use property nodes of an empty control to empty your waveform chart.
Here's a little image of how to create an empty control waveform. Hope this helps !
Julien
(4,001 Views)
Hello AxE,
you can create your own waveform with "build waveform". If you connect an empty data array you get an empty waveform...
(4,001 Views)
You can also have a waveform with values of "Not a Number" (NaN) and they do not appear in the graph. You can also use NaN if you need gaps in the graph. This method can help you initialize the memory for a better performance.
I hope this helps
Juan Carlos
N.I.
(4,001 Views)
