how to create a hsv image
I am going to create a HSV image based on my data (H, S, V are all available). However I find that in Imaq creat VI, there is no HSV image, so how should I creat a hsv image?
I know that one way is to creat a RGB image and convert my HSV data to RGB data,  however this will make my image process difficult, since I need to use some image process VIs that directly using HSV.
Thank you
Miao
(3,952 Views)
I don't think you can create an HSV image.  You create an RGB image and then extract the H, S, and V planes as desired.
(3,943 Views)
if you want to use rgb images in hsv color space, just load them as hsv; IMAQ Create -> Image Type -> HSL (U32)
Felix
(3,902 Views)
