Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
how to create a ocx control with labview
lincoln
Member
09-10-2001
11:03 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I want to use labview to create a ocx control,and I want to use this ocx control under VB or VC,just like componentworks and componentworks++.Can this work?
0
Kudos
Message
1
of 3
(3,057 Views)
Reply
Re: how to create a ocx control with labview
LBoltzmann
Member
09-11-2001
11:45 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
LabVIEW has the ability to be used as an automation server from VB or VC. The ability to act as a container object is not supported.
0
Kudos
Message
2
of 3
(3,057 Views)
Reply
JellyBeans
Active Participant
09-11-2001
12:05 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Presently you can not create ActiveX controls in LabVIEW. You can however create LabVIEW EXE that support ActiveX Automation.
A Rafiq
1
Kudo
Message
3
of 3
(3,057 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
