how to create a program with daq and data analyzation
hello,
i hope to find some new ideas to solve my problems.
in my latest projects there are a few bad solutions. there are between 20 and 50 global variables and many parallel while loops.
the problem is to combine the daq, data analyzation and programm usage.
my idea is to use the programm when the daq runs and analyze the data. that are three parallel operations.
has anyone an idea how build this in structured code?
a schematic diagramm with the used synchronization tools would be enough.
thanks
markus
(2,715 Views)
i ask for one small clarification, are you having a single daq card to acquire from?
or are you talking about multiple DAQ cards in as many while loops?
(2,708 Views)
I've got an m-series card with 16 AI, 4AO and 48DIO.
markus
(2,705 Views)
In general, Notifiers should solve your problem.
take a look at this example VI (from labview examples)
It demonstrates the use of notifiers to synchronize data shared between parallel loops.
regards
(2,702 Views)
