altenbach,
thanks for the great info. i was able to copy it! had no idea that was possible.
1. i've been trying to save it in the "user control palette" by copy and past method but doesn't work. how do i handle that?
2. when i drag n drop a tank on the screen from the palette, there seem to be only on input or output terminal but in this example (see attached file), the tank seem to have 2 terminals (one for in-flow of fluid and the other for out-flow).
i could copy n paste that example also, but what i'm trying to do is a little bit different.
should i assume that if i connect a pipe to the side of the tank and flow some fluid thru the pipe, the tank will automatically begin to fill-up or receive the fluid?
also, for the tank that i'm using,
it's initially filled (for example, a gas tank or cylinder ... filled with say Oxygen or Nitrogen). hope you get the idea.
thanks
-r
