how to create an gray scale png image from intensities values
  I would like create a gray scale png image from set of intensities values which is saved in excel sheet . Is IMAQ tool necessary for this vi?
thanks & regards
Manoj
(2,822 Views)
You posted in the feedback forum, which is not correct for your question. I am guessing you are talking about LabVIEW since you mention "vi".
The answer is NO. Plain LabVIEW is sufficient.
(2,819 Views)
Hi manojk,
To expand Altenbach's answer:
Use an intensity graph to display your 2D array and set a gray scale color ramp for the Z axis!
(2,678 Views)
