how to create event driven timer
Since the while loop spins anyway, you should replace the event structure with a simple case structure. That's all you need.
Message 51 of 56
(2,825 Views)
Thanks for replying I tried that too but is almost the same result. I tried a Case structure. When i ran it. The preogram starts to ask me file path again and again after every loop, so i gave it a default file path and gave it instruction to delete file data every time the loop runs but really what i want is that the data continues to be written where it stopped in the first loop. I want a way to collect data without overwriting actually, in the same file. Please help!!!
Message 52 of 56
(2,823 Views)
You need to make sure that there is a valid file path in the "file path" control. Is there?
If you want to append to an existing file, keep the file path in a shift register and set append=true of the write VI.
Message Edited by altenbach on 06-12-2008 10:15 AM
Message 53 of 56
(2,810 Views)
Hello troy,
Please could you help me find a way to use the posted VI to  start the timer when a condition is met (as for example when the voltage of a signal crosses a certain value).
Actually I tried wiring a control button in the some way to start the timer but it didn't work. kindly let me know how I can deal with this issue. ( I am not sure how to use the event structure). Please find attached the modified (not working) VI.
Thanks a lot!
Bill
Message 54 of 56
(2,456 Views)
Bill El Sayed wrote:
Hello troy,
There are many VIs posted above, please clarify which one you mean. Troy did not post any VIs.
This is an old thread, so I would suggest to start a new one.
THere is no attachment. Attach your VI so can see what's wrong.
Message 55 of 56
(2,438 Views)
I second everything altenbach said.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 56 of 56
(2,414 Views)
