how to create excel chart
I try searching in this forum and i get something in this forum , http://forums.ni.com/ni/board/message?board.id=170&message.id=23111&query.id=44672#M23111 but i still can't figure out how should i create a simple chart.
As for my case, i just want to create a simple chart with xlXYScatterSmoothNoMarkers with 2 columns of 401 datas named column D and G.
How do i create that using activeX? Or do i had to use marco instead that? Need some advices on that or any help.
Ander
(3,327 Views)
Hi Ander,
in the above link is already an example. Where do you have problems with it?
See also this link for more information about ActiveX and Excel.
http://forums.ni.com/ni/board/message?board.id=BreakPoint&thread.id=2391&view=by_date_ascending&page...
Mike
(3,317 Views)
How do i start off with activex to get the chart to get data from the 2 columns and plot out a chart? Actually i tried to edit the 1st url i posted and i can't even get the program to work after i add. I am asking how should i do a simple chart? Or anywhere then the url provided by mike
(3,300 Views)
