how to create liscence for my software?
hello ni,
                  I want to create the liscence for  my software, which is made by labview.  like a key number, it should ask before installing my software, if the key number is correct then only it should install to the system. otherwise dont install.
how to do this this with labview installer package... i find creating istaller in labview there is no option for this....
do you have any other logic for the same how can i do that?
Balaji DP
(2,570 Views)
You are correct in that the stock installer does not have this capability. You will need to use a third-party installer.
(2,547 Views)
