how to create session id from different string controls
(3,590 Views)
fais,
Can you please post more information on this issue? I am not sure what you are asking for in your question. Thank you.
Randy Hoskin
http://www.ni.com/ask
(3,590 Views)
well i have some control strings, like Name,surname,
date of birth and date. with this strings i would like
to genrate session id that takes date in yymmdd format,then first two alphabets of surname,then name, then date of birth. so which lab view functions should i use for that ?
(3,590 Views)
fais,
Please create the VI you are talking about and save some default data into all of the controls. Also on the front panel, place the session ID that should be generated by that data. Now, post your VI to a response so I can download it. I can then take this VI and help you create the functionality. (Please post what version of LabVIEW you are using.)
My guess it that you are going to need to use a good number of string concatenations as well as a few string indexes to get parts of strings out. As for the date, you can use a Property node with the Numeric Text.Text property to get the actual string displayed on the front panel for the date and parse out the parts that you want.
Randy Hoskin
h
(3,590 Views)
thanks for your reply. well i am sending you the vi and i need the generated string that should be in following format.
yymmdd first 2 alphabets of last name first 2 alphabets of first name yy of birth.
i am using labview version 6.1.
with regards
(3,590 Views)
Try this and let me know how it works.
Randy Hoskin
(3,590 Views)
thanks a lot it is working
(3,590 Views)
