how to create state diagram (for state machine)
Hallo  all.
In my previous visit here, i saw picture of state diagram (bubbles with connection),
How to create that in labview (if there is such option) ?
or, which other software create state diagram.
thanks   🙂
(3,062 Views)
There is the State Diagram Toolkit (additional tool from NI for LabVIEW) with good interface and unreadable code 😉
It gives you a State Diagram Editor at Functions palette.
It is very good tool for state diagram visualization, but readability of the code is controversial.
When you will get a clear picture of a diagram from State Diagram Editor, I suggest use classic state diagram pattern: case structure driven by typedef enum in while loop.
Regards
Mikrobi (Zbigniew St. Sobków)____________________________________________________________
"You can lead a horse to water, but if you can get him to float on his back you've got something."
(3,053 Views)
Here are some links that can be usefull to NI:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/13747
https://www.ni.com/en/support/documentation/supplemental/16/simple-state-machine-template-documentat...
Hope this helps...
Barp - Control, Simulation, RTT and HIL - National Instruments
(3,020 Views)
