how to create the object reference without using GOOP Tool
Hi all,
Please clarify doubt. Is it possible to create the object reference without using GOOP Tool.
if so, please help me how to implement the same.
Ram
(3,195 Views)
Hi Ram,
which object do you mean? Can you explain a bit more?
Mike
(3,187 Views)
Object references are references to ... objects, which are instances of classes. Hence, it makes no sense to use them without a class. Also, which GOOP tool are you referring to? There's lots of GOOP tools, including the object-oriented programming that's built into LabVIEW.
(3,184 Views)
If you have LabVIEW 8.2 or greater, you can create an reference object by creating a LabVIEW object whose single data element is a queue reference.  The queue is initialized to one element and contains a cluster with the object data.  This is a single-element-queue "global".  You can find out more about single-element-queue "globals" by searching these forums.  You can find some example code here.
(3,162 Views)
